::UnselectLastEntry
This command deselects the last mdl3StateEntry widget that the user has selected. The value in the last widget will be saved to the model depending on arguments passed in.
::model::mdl3StateEntry::UnselectLastEntry path bOnlyIfActivated bForce
MotionView Tcl GUI
- path
- This argument take either of two forms. This argument determines the widget whose
Activated status is used in conjunction with the bOnlyIfActivated
argument below.
- Full path to the mdl3StateEntry widget of interest. The path argument is the return value of the model::mdl3StateEntry procedure used to create an mdl3StateEntry.
- Empty string, "". When an empty string is specified for this argument then the widget of interest is whichever mdl3StateEntry widget the user selected last.
- bOnlyIfActivated
- Boolean parameter:
- True
- The last widget will be deselected only if the widget in the path parameter is currently active.
- False
- The last widget will always be deselected.
- bForce
- Boolen parameter:
- True
- The value in the last widget selected will be saved to the model.
- False
- The value in the last widget selected will NOT be saved to the model.
To select an mdl3StateEntry
widget:
model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entPnt Point p_0 "\"Point 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set lbl [ label $dlg.frm.lbl -text "X" -width 3 -anchor w ]
grid $lbl -row 0 -column 0 -sticky nws
set stEntry [ model::mdl3StateEntry .dlg.frm.stEntry entPnt "x" ]
grid $stEntry -row 0 -column 1
model::mdl3StateEntry::UnselectLastEntry $stEntry false false
entPnt ReleaseHandleErrors
Currently, if the bForce argument is set to true and there is no last entry selected then this procedure will cause an error.
