::ChangeTitle
This command sets the title for the wizard dialog window. This command can be called any time after the wizard dialog has been created.
::model::mdlWizardDlg::ChangeTitle title
MotionView Tcl GUI
- title
- The text to be displayed in the title bar for the wizard dialog window.
To change the title of the wizard
dialog:
namespace eval ::my_wizard {
variable p_dlg ""
proc ::my_wizard::Run {} {
set mangle [::model::GetMangle my_wizard_Run]
variable p_dlg
set p_dlg [::model::mdlWizardDlg wiz$mangle -width 400 -height 200 \
-title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
::model::mdlWizardDlg::ChangeTitle "New Title!"
::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnClose { args } {
variable p_dlg
hwt::UnpostWindow $p_dlg
return 1
::my_wizard::Run Errors
None.
