::PostMessage
This command posts a message to the message log for the wizard dialog. When the wizard dialog is closed, these messages are copied to the main application message log.
::model::mdlWizardDlg::PostMessage msg type
MotionView Tcl GUI
- msg
- The message that is to be displayed in the message log for the wizard dialog.
- type
- The type of message being posted to the message log. It is normally either “Error”, “Warning”, or “Info”, but can be any arbitrary text.
To add the time to the message log of the wizard dialog when the user clicks on the “Time”
button:
namespace eval ::my_wizard {
variable p_dlg ""
proc ::my_wizard::Run {} {
set mangle [::model::GetMangle my_wizard_Run]
variable p_dlg
set p_dlg [::model::mdlWizardDlg wiz$mangle -width 600 -height 400 -show_eb \
-title "My Wizard" -showExport false -callback "::my_wizard::OnClose"]
set frm [::model::mdlWizardDlg::GetButtonFrame $p_dlg]
::model::mdlWizardDlg::AddButtonToActionFrame $frm btnShow 4 "Time" ::my_wizard::OnTimeButton
::model::mdlWizardDlg::ShowDialog
proc ::my_wizard::OnTimeButton {} {
::model::mdlWizardDlg::PostMessage [clock format [clock seconds]] Info
proc ::my_wizard::OnClose { args } {
variable p_dlg
hwt::UnpostWindow $p_dlg
return 1
::my_wizard::RunErrors
None.
