hwIAMFExportOptions SetEncoder
Sets the type of encoding used when exporting AMF video files.
hwIAMFExportOptions_handle SetEncoder encoder
HyperView Tcl Modify
This command sets the type of encoding used when exporting AMF video files.
Note: This
parameter is used when exporting AMF files from any client during video
capture.
- encoder
- The encoder type. Options are: “jpeg” or “zlib”.
To set the encoder used when exporting AMF
files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions SetEncoder jpegError
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument quality is not in the range listed above.
