hwIAMFExportOptions SetQuality
Sets the quality used when exporting AMF files using the JPEG encoder.
hwIAMFExportOptions_handle SetQuality quality
HyperView Tcl Modify
This command sets the quality used when exporting AMF files using the JPEG
encoder.
Note: This parameter is used when exporting JPEG encoded AMF files from any client
during video capture.
- quality
- The quality to be used when exporting JPEG encoded AMF files. This must be between 0 and 100 (exclusive).
To set the current quality used when exporting JPEG encoded AMF
files:
mySessionName GetAMFExportOptionsHandle myAmfOptions
myAmfOptions SetQuality 90Errors
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument quality is not in the range listed above.
