hwIAMFExportOptions SetSize
Sets the relative image size (percent) used when exporting AMF files.
hwIAMFExportOptions_handle SetSize size
HyperView Tcl Modify
This command sets the relative image size (percent) used when exporting AMF
files.
Note: This parameter is used when exporting AMF files from either the video or
animation clients during video capture.
- size
- The relative image size (in percent) to be used when exporting AMF files. Values include: 100, 75, 50, or 33.
To set the current relative image size used when exporting AMF
files:
mySessionName GetAMFExportOptionsHandle
myAmfOptions
myAmfOptions SetSize 50Error
Returns 0 if successful, or an error code (3 = HW_InvalidHandle) - if the handle used to invoke the method is no longer valid or
(HW_InvalidArgs) - if the value of the argument size is not one of those listed above.
