hwIH3DExportOptions GetWritePreviewImage
Gets whether a preview image should be imbedded in the file.
hwIH3DExportOptions_handle GetWritePreviewImage
Tcl Query
Returns true or false, depending on whether embedding a JPEG preview is enabled.
The H3D format supports holding a JPEG preview image that HyperView Player can display in a browser before the player is activated.
To check if a JPEG preview image is embedded in the
file:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWritePreviewImageErrors
None.
