hwIH3DExportOptions SetCompressionLevel
Sets the level of non-lossy compression.
hwIH3DExportOptions_handle SetCompressionLevel level
Tcl Modify
This command covers only non-lossy compression. The default value for the level is 7, which gives a good balance between speed and size-reduction. The better the compression, the slower the file may be to write.
- level
- A number from zero to nine.
To increase the level of lossless compression from the default (7) to the maximum
(9):
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetCompressionLevel 9Error
None.
