hwIH3DExportOptions SetWriteEntityIDs
Sets whether the IDs should be written out with the file.
hwIH3DExportOptions handle SetWriteEntityIDs flag
Tcl Modify
Largely ignored in the 6.0 and later. In previous versions, there was an advantage in efficiency to writing index-based files. This is no longer true.
- flag
- True or false.
To force indices to be written (no longer
recommended):
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetWriteEntityIDs falseErrors
None.
