hwISession GetGIFExportOptionsHandle
Returns the GIF export options interface handle for the session.
hwISession_handle GetGIFExportOptionsHandle exportoptionhandle
Tcl Query
This command provides access to the GIF Export Options interface object.
- exportoptionhandle
- The user-defined name of the export options handle that you want to create with this command. In the example below, the export options handle is “gifExportOptionsHandle”.
To retrieve the GIF export options interface handle for a
session:
hwi GetSessionHandle sessHandle
sessHandle GetGIFExportOptionsHandle gifExportOptionHandle
Returns: gifExportOptionsHandleErrors
Returns the file handle name if successful.
Returns an error message if the command fails.
