hwISession SaveSessionFile
Writes the session to the given filename.
hwISession_handle SaveSessionFile filename, savealldata
Tcl Modify
- filename
- The session file to be written.
- savealldata (Optional)
- Allows you to save all the data in the session file as opposed to only references to the data.
To save the current session as a report template to
"myfile":
mySessionName SaveReportTemplate myfileError
Success (0) or an error code.
