hwISession IsClientLoaded
Indicates whether or not the specified client type is available in the current session.
hwISession_handle IsClientLoaded client_name
Tcl Query
Returns true if the requested client is loaded; false otherwise.
- client_name
- The name of the client for which you are querying.
To determine if the "Plot" client is loaded in the current
session:
mySessionName IsClientLoaded PlotErrors
None.
