plt3DISurface GetDataSourceHandle
Gets the handle of a particular data source from the surface.
plt3DISurface_handle GetDataSourceHandle iSource name
Tcl Query
Surfaces are defined by a collection of data sources.
- iSource
- The name of the new handle.
- name
- The name of data source.
To get the X, Y, Z and W (contour) data source handles from an existing
surface:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName GetDataSourceHandle dsX x
mySurfaceName GetDataSourceHandle dsY y
mySurfaceName GetDataSourceHandle dsZ z
mySurfaceName GetDataSourceHandle dsW wErrors
None.
