plt3DISurface GetVisibility
Gets whether surface is visible.
plt3DISurface_handle GetVisibility
Tcl Query
Surfaces can be rendered invisible without destroying them. If the visibility flag is set to false, a surface will simply not be drawn (and won’t appear in the legend). However, the surface will still be displayed in the surface list and can be made visible by changing the flag back to true.
Returns true or false.
To check if an existing surface is
visible:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
mySurfaceName GetVisibilityErrors
None.
