plt3DISurface SetParametric
Sets whether a surface’s X, Y, and Z vectors are parameterized by U and V vectors.
plt3DISurface_handle SetParametric flag
Tcl Modify
Parametric surfaces contain hidden U and V vectors, which can be used to parameterize X, Y, and Z. If this flag is set, U and V are evaluated before X, Y, and Z.
- flag
- Parametric, true or false.
To make an existing surface
parametric:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName SetParametric trueErrors
None.
