plt3DIWaterfall GetGenerateCurves
Gets whether waterfall is visible.
plt3DIWaterfall_handle GetGenerateCurves
Tcl Query
Waterfalls can be created in two ways: either by adding individual curves (slices), one at a time, or by defining matrices mathematically that are used to generate the constituent curves automatically.
Returns true or false.
To check if an existing waterfall is
math-based:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName GetGenerateCurvesErrors
None.
