plt3DIWaterfall GetParametric
Gets whether a waterfall’s X, Y, and Z vectors are parameterized by U and V vectors.
plt3DIWaterfall_handle GetParametric
Tcl Query
Parametric surfaces contain hidden U and V vectors, which can be used to parameterize X, Y, and Z. If this flag is set, U and V will be evaluated before X, Y and Z.
To test if an existing waterfall is
parametric:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetParametricErrors
None.
