plt3DIWaterfall RemoveSlice
Removes a slice from a waterfall.
plt3DIWaterfall_handle RemoveSlice index
Tcl Query
- index
- The index of the slice to remove (one-based).
To remove an slice from an existing
waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName RemoveSlice 1Errors
None.
