poIMeasure AddNode
Adds the given node of the current/specified model to the measure.
poIMeasure_handle AddNode "model_id node_id"
HyperView Tcl Modify
This command adds the given node of the current/specified model to the measure.
Note: HyperView allows you to specify the measure between
several models loaded (overlaid) into the same window. This is why you have to provide the
model ID and node ID (or element ID) when you add a node or element to the
measure.
- node_id
- The node ID in one of three forms:
- "m1 n1" (A regular node)
- This option adds a node from a model with the ID = m1 and the node ID = n1. This is the most common function you will use to create measures from scripts.
To add a node from model ID = 1, node ID = 334567 to measure
msr1:
msr1 AddNode "1 334567"Errors
Returns 0 if successful, otherwise an error code.
