poIMeasure GetEntityList
Gets a list of measure entities.
poIMeasure_handle GetEntityList
HyperView Tcl Query
This command retrieves a list of measure entities. The returned list is formatted as
follows depending upon the underlying measure type. The size of the returned list depends
upon the size of the measure group and the number of entities that contribute to the
specific measure type.
- Position, Relative Displacement, Distance Between, Incremental Distance, Relative Angle, Angle Between, Incremental Angle
{<model id> <part pool> <part id> <node pool> <node id>}- Minimum Distance
{<model id> <part pool> <part id> <entity pool> <entity id> <model id> <part pool> <part id> <entity pool> <entity id>}
To get the entity list for a measure with ID 3:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetMeasureHandle measure 3
measure GetEntityList
hwi CloseStack
None.
