poIMeasure GetType
Gets the measure type.
poIMeasure_handle GetType
HyperView Tcl Query
This command returns the measure type. Options include: Position, Relative Displacement, Distance Between, Incremental Distance, Relative Angle, Angle Between, Incremental Angle, Static MinMax Result, Dynamic MinMax Result, Nodal Contour, Elemental Contour, Component Contour, Node Path, Circle Radius, and Yaw Pitch Roll.
To get the measure type:
Note: This example assumes that the d3plot file
(demos/mv_hv_hg/animation/dyna/bumper) has been
loaded.
variable t [expr rand()];
hwi GetActiveClientHandle cl$t
set measid [cl$t AddMeasure "Circle Radius"]
cl$t GetMeasureHandle meas$t $measid
meas$t AddNode 516
meas$t AddNode 226
meas$t AddNode 242
cl$t Draw
meas GetTypeErrors
None.
