poIModel GetBoundingBox
Returns the bounding box coordinates of the model.
model_handle GetBoundingBox displayed_entities
HyperView Tcl Query
This command returns the bounding box values of the model. The return value is a list of six numbers corresponding to the xyz coordinates of the lower left corner and the upper right corner.
- displayed_entities (Optional)
- By default, the bounding box is calculated for the whole model. If this argument is set to "true", then the bounding box will be calculated only for the displayed entities.
To retrieve the bounding box of the
model:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
# Add 3 Result files (bumper, bumper foam, airbag)
set mid [client_handle AddResultMathAnalysis "Standard", "c:/samples/bumper/d3plot", "c:/samples/bumper/d3plot", 0, 0]
client_handle GetModelHandle model_handle $mid
set bbox [model_handle GetBoundingBox]
hwi CloseStackErrors
None.
