poIModel RemoveAssembly
Removes an assembly from the model.
poIModel_handle RemoveAssembly assemblyID
HyperView Tcl Modify
This command removes an assembly from the model.
- assemblyID
- The ID of the assembly to be removed from the model.
To remove an assembly with ID 1 from the
model
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myModelName RemoveAssembly 1Errors
Returns 0 if successful, or an error code (HW_IDNotFound) - if the specified parent assembly ID does not exist in the model or (HW_InvalidHandle) - if the handle used to invoke the method is no longer valid.
