poIModel GetEntityInfo
Returns the property information for a given entity.
model_handle GetEntityInfo entity property entityid
HyperView Tcl Query
This command returns information regarding the requested property. The possible values for the "property" argument depend upon the "entity" argument.
- entity
- The possible values for this argument are "node" or "element".
- property
- For a "node" entity type, the property argument may have a value of "coord".
- entityid
- The entity id for which the property is requested.
To create several selection sets on the current model and request a selection set
list:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# Get Information about the node coordinates, element centroid, element normals
model_handle GetEntityInfo node coord "Node 500"
model_handle GetEntityInfo element centroid "Shell 156"
model_handle GetEntityInfo element normal "Shell 100"
hwi CloseStackErrors
Returns "error" if an invalid entity type/property combination is passed.
