poIRenderOptions SetCollectorColor
Sets the selection highlighting color.
poIRenderOptions_handle SetCollectorColor color
HyperView Tcl Modify
This command sets the highlighting color that will be used for entity selection. It corresponds to the graphical user interface option .
- color
- Set the color using the RGB format (for example, 255 255 255).
Returns 0 if successful, otherwise an error code.
