poIRenderOptions SetStereo
Enables/disables the stereoscopic display.
poIRenderOptions_handle SetStereo arg1
HyperView Tcl Modify
This command enables the stereoscopic (3D) display if arg1 is set to true and the environment variable HW_STEREO is set to 1. If arg1 is set to false, the stereoscopic (3D) display is disabled.
- arg1
- Set to true to enable the stereoscopic display (provided the environment variable HW_STEREO is also set to 1), or set to false to disable the stereoscopic display.
To enable the stereoscopic
display:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetStereo true
hwi CloseStackErrors
Returns a value of "3" if the handle is invalid, or "1" if the environment variable HW_STEREO does not equal "1".
