poIRenderOptions SetMeshDetails
Sets the current value of the mesh detail slider.
poIRenderOptions_handle SetMeshDetails value
HyperView Tcl Modify
This command sets the value of the mesh detail slider (1 to 100). A lower value means that mesh lines are less likely to be displayed for fine meshes, and vice versa. A value of 100 means mesh lines are always shown, regardless of how fine the meshes are.
- value
- The mesh detail slider value (1 to 100).
To set the value of the mesh detail
slider:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetMeshDetails Value
hwi CloseStackErrors
None.
