poISelectionSet GetColor
Retrieves the visible color setting on the current selection.
selectionSet_handle GetColor
HyperView Tcl Query
This command returns the RGB color coding for the selection set. It affects the display color of a visible selection set and the display color of visible entity IDs.
To create a selection set containing all nodes, make it visible in the graphic area, and
use GetColor and SetColor for displaying the entities
and their IDs in the defined
color:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle AddSelectionSet node
puts "Current selection sets: [model_handle GetSelectionSetList]\n"
model_handle GetSelectionSetHandle selection_set_handle 1
selection_set_handle SetLabel "OurNodeSelectionSet"
selection_set_handle Add all
puts "Current selection set ID: [selection_set_handle GetID]"
puts " Label: [selection_set_handle GetLabel]"
puts " Size: [selection_set_handle GetSize] [selection_set_handle GetType]s"
puts " Default color: [selection_set_handle GetColor]"
puts "----------------------"
puts " Set color to red: "
selection_set_handle SetColor red
puts "Red = [selection_set_handle GetColor]"
selection_set_handle SetVisibility true
selection_set_handle SetColor "255 0 255"
selection_set_handle SetIDVisibility true
hwi CloseStackErrors
This command should not return any errors.
