poISelectionSet Subtract
Subtracts entities from the selection set.
selectionSet_handle Subtract selection
HyperView Tcl Query
This command removes entities specified by the argument selection from the current selection set (for example, Subtract “id 1-10”).
- selection
- To see a detailed list of possible selections, please see Add and its detailed example.
To create a selection set for all of the nodes and use Subtract to remove nodes from it
(please see the example for the command Add, use the same syntax, and
replace the command name Add with
Subtract):
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSelectionSetHandle selection_set_handle [model_handle AddSelectionSet node]
selection_set_handle SetLabel "OurNodeSelectionSet"
puts "Possible list selections: [selection_set_handle GetSelectByList]"
selection_set_handle Add all
puts "Add all : [selection_set_handle GetSize] [selection_set_handle GetType]s"
#subtract nodes in the ID range of 1 to 100
selection_set_handle Subtract "id 1-100"
puts "Subtract id 1-100 : [selection_set_handle GetSize] [selection_set_handle GetType]s"
hwi CloseStackError
This command should not return any errors. If the argument is invalid, nothing will be subtracted from the selection set.
