poISelectionSet GetLabel
Retrieves the label of the current selection set.
selectionSet_handle GetLabel
HyperView Tcl Query
This command returns the label of the selection set.
To create a selection set containing all nodes, make it visible in the graphic area, and
use GetLabel to retrieve the label of the current selection
set:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle AddSelectionSet node
puts "Current selection sets: [model_handle GetSelectionSetList]\n"
model_handle GetSelectionSetHandle selection_set_handle 1
selection_set_handle SetLabel "OurNodeSelectionSet"
selection_set_handle Add all
puts "Current selection set ID: [selection_set_handle GetID]"
puts " Label: [selection_set_handle GetLabel]"
puts " Size: [selection_set_handle GetSize] [selection_set_handle GetType]s"
puts " Default color: [selection_set_handle GetColor]"
puts " Default visibility: [selection_set_handle GetVisibility]"
puts "----------------------"
selection_set_handle SetVisibility true
puts " Current visibility: [selection_set_handle GetVisibility]"
hwi CloseStackErrors
This command should not return any errors.
