MotionView S-Function in Simulink Arguments
- S-Function name
- Enter one of the following:
- S-Function parameters:
- Enter these three required parameters and correspond to the following
inputs to the MotionSolve library,
mbd_d.exe:
- MotionSolve model name
xml). - MotionSolve output name
mrf). - MotionSolve user library name
dll; if a user library is not used, enter empty quotes, ' ', to signify this).
- S-Function modules
- Does not need a parameter
