*AIRBAG_SHELL_REFERENCE_GEOMETRY
LS-DYNA Input Interface KeywordDefine the reference state for elements belonging to a part using given element and node identifiers with possible scaling for the nodes with defined scale center and scale factor.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *AIRBAG_SHELL_REFERENCE_GEOMETRY_{OPTION} | |||||||
If OPTION = ID, insert the following line
| FscaleX | FscaleY | FscaleZ | node_IDc |
| shell_ID | part_ID | node_ID1 | node_ID2 | node_ID3 | node_ID4 |
Definition
| FscaleX | X scale factor. Default = 1.0 (Real) |
| FscaleY | Y scale factor. Default = 1.0 (Real) |
| FscaleZ | Z scale factor. Default = 1.0 (Real) |
| node_IDc | Center node
identifier. (Integer) |
| shell_ID | Shell
| part_ID | (Optional) Part
| node_ID1 | Node 1
| node_ID2 | Node 2
| node_ID3 | Node 3
| node_ID4 | Node 4
- This keyword maps to /EREF and /TRANSFORM/SCA.
