/EOS/TABULATED
Block Format Keyword Describes the tabulated equation of state P = A ( µ ) + B ( µ ) E MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadcfacqGH9aqpcaWGbbGaaiikaiaadwlacaGGPaGaey4kaSIa amOqaiaacIcacaWG1cGaaiykaiaadweaaaa@40B6@ .
/EOS/TABULATED/mat_ID/unit_ID
eos_title
fct_IDA XscaleA FscaleA
fct_IDB XscaleB FscaleB
E0 Psh
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
eos_title EOS title.
fct_IDA Function identifier for function A.
Default = 0 (Integer)
XscaleA Scale factor for function A( μ ) abscissa.
Default = 1.0 (Real)
FscaleA Scale factor for function A( μ ) ordinate.
[ Pa ]
fct_IDB Initial pressure.
(Real)
XscaleB Scale factor for function B( μ ) abscissa.
FscaleB Scale factor for function B( μ ) ordinate.
E0 Initial value for E.
(Real)
[ Pa ]
Psh Pressure shift.
(Real)
[ Pa ]
#RADIOSS STARTER
/BEGIN
Sample_for_air
      2022         0
                   g                  mm                  ms
                   g                  mm                  ms
/MAT/HYDRO/7/1
AIR
#              RHO_I               RHO_0
             1.22e-6                   0
#                Knu                Pmin
              1.5E-2                   0
/EOS/TABULATED/7
Ideal Gas using tabulated EoS P(µ)=A(µ)+B(µ)*E ; units {g,mm,ms} ; P(0)=0.1 MPa
#   A_func                       XscaleA             FscaleA
         0                             0                   0
#   B_func                       XscaleB             FscaleB
      1002                      1.000000            1.000000
#                 E0                 PSH
                0.25                 0.1
/FUNCT/1002
EOS FUNCT - B(µ) = (GAMMA-1).(1+µ) ; where gamma=1.4 ; units {g,mm,ms}
#                  X                   Y
                  -1                 0.0
                   0                 0.4
                   9                 4.0
                  99                40.0
                9999              4000.0
#ENDDATA
  1. Tabulated EoS is defined with:
    Where,
    μ
    is defined as µ = ρ ρ 0 − 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadwlacqGH9aqpdaWcaaWdaeaapeGaeqyWdihapaqaa8qacqaH bpGCpaWaaSbaaSqaa8qacaaIWaaapaqabaaaaOWdbiabgkHiTiaaig daaaa@3F60@
    E MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa Wdbiaadweaaaa@3746@
    is ρ 0 e MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa Wdbiabeg8aYnaaBaaaleaacaaIWaaabeaakiaadwgaaaa@3A16@ (SI unit J/m3 or Pa)
    A MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa Wdbiaadweaaaa@3746@ and B MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa Wdbiaadweaaaa@3746@
    are user-defined functions
  2. Optional scale factors are introduced such as:
    P = F s c a l e A . A ( µ X s c a l e A ) + F s c a l e B . B ( µ X s c a l e B ) E MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadcfacqGH9aqpcaWGgbGaam4CaiaadogacaWGHbGaamiBaiaa dwgadaWgaaWcbaGaamyqaaqabaGccaGGUaGaamyqaiaacIcadaWcaa qaaiaadwlaaeaacaWGybGaam4CaiaadogacaWGHbGaamiBaiaadwga daWgaaWcbaGaamyqaaqabaaaaOGaaiykaiabgUcaRiaadAeacaWGZb Gaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGcbaabeaakiaa c6cacaWGcbGaaiikamaalaaabaGaamyTaaqaaiaadIfacaWGZbGaam 4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGcbaabeaaaaGccaGG PaGaamyraaaa@5C00@
  3. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
