/INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
| /INITRUSS/FULL/unit_ID | |||||||||
| truss_ID | prop_type | ||||||||
| EINT | F | AREA | |||||||
Definition
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| truss_ID | Element
identifier. (Integer) |
| prop_type | Property
set. (Integer) |
| EINT | Total internal
energy. (Real) |
| F | Truss element normal
force. (Real) |
| AREA | Cross-sectional area
of the truss. (Real) |
| Plastic
strain. (Real) |
