*MAT_054 (ENHANCED_COMPOSITE_DAMAGE)
LS-DYNA Input Interface KeywordDefines an orthotropic shell composite material for unidirectional layers with Chang-Chang failure model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_054 or *MAT_ENHANCED_COMPOSITE_DAMAGE | |||||||
| mat_ID | E1 | E2 | E3 | 12 | |||
| G12 | G23 | G31 | AOPT | ||||
| XP | YP | ZP | A1 | A2 | A3 | MANGLE | |
| V1 | V2 | V3 | D1 | D2 | D3 | ||
| TFAIL | |||||||
| XC | XT | YC | YT | SC | BETA | ||
| Blank card | |||||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial density
. (Real) |
| E1 | Young’s modulus in material
directions 1. (Real) |
| E2 | Young’s modulus in material
directions 2. (Real) |
| E3 | Young’s modulus in material
directions 3. (Real) |
| 12 | Poisson’s ratio between directions
1 and 2. (Real) |
| G12 | Shear modulus in direction
12. (Real) |
| G23 | Shear modulus in direction
23. (Real) |
| G31 | Shear modulus in direction
31. (Real) |
| AOPT | Material axis flag.
(Integer) |
| XP, YP, ZP | Coordinates of reference point for
AOPT = 1 and
4. (Real) |
| A1, A2, A3 | Vector defining first orthotropy
direction for AOPT =
2. (Real) |
| MANGLE | Material angle for
AOPT = 1 and
3. (Real) |
| V1, V2, V3 | A vector which in combination with
element normal defines the first orthotropy direction for
AOPT = 3 and
4. (Real) |
| D1, D2, D3 | Components of vector for
AOPT =
2. (Real) |
| TFAIL | Time step for element
deletion. (Real) |
AOPT = 0 and
3. (Real) |
| XT | Yield stress in tension in
direction 1. (Real) |
| XC | Yield stress in compression in
| YT | Yield stress in tension in
direction 2. (Real) |
| YC | Yield stress in compression in
| SC | Maximum shear
stress. (Real) |
| BETA | Shear scaling factor. Default = 0 (Real) |
- This material law is mapped to /MAT/LAW25 (COMPSH) (Iform=0) and /FAIL/CHANG.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
