/MAT/LAW90
Block Format Keyword This law describes the visco-elastic foam tabulated material. This material law can be used only with solid elements.
/MAT/LAW90/mat_ID/unit_ID
mat_title
ρ i
E0 ν MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AE@ Tflag
NL Ismooth Fcut Shape Hys Alpha
If NL ≠ 0, each loading function per line
fct_IDL ε ˙ L FscaleL
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
E0 Initial Young's modulus. 3
(Real)
[ Pa ]
Tflag Tensile behavior flag.
= 1 (Default)
Tensile and compression follows the input curves.
= 2
Compression follows the input curves. Tensile behavior is linear elastic using E0.
(Integer)
ν MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AE@ Poisson's ratio.
(Real)
Ismooth Smooth strain rate option flag.
= 0 (Default)
No strain rate smoothing.
= 1
Strain rate smoothing active.
(Integer)
Fcut Cutoff frequency for strain rate filtering.
Default = 1030 (Real)
[Hz]
NL Number of loading functions.
(Integer)
fct_IDL Load function (in compression) identifier.
(Integer)
ε ˙ L Strain rate for load function.
(Real)
[ 1 s ]
FscaleL Load function scale factor.
(Real)
[ Pa ]
Shape Shape factor.
Default = 1.0 (Real)
Hys Hysteresis unloading factor.
Alpha Exponent for unloading (used only if Hys > 0).
Default = 1 (Real)
Example (Foam)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                  mm                  ms
#-  1. MATERIALS:
/MAT/LAW90/1/1
foam
#              RHO_I
                3E-8
#                 EO                  NU    Tflag
                0.01                   0        0
#    Nload   Ismooth               F_cut               Shape                 Hys               Alpha
         3         1                  10                 10.                0.15                   0
#  fct_IDL          Eps_._load          Fscaleload
        12                  .1                   0
        13                   1                   0
        13                 100                   0
#-  2. FUNCTIONS:
/FUNCT/12
NULL
#                  X                   Y
              -0.300              -0.546
              -0.200              -0.534
              -0.100              -0.398
               0.000               0.000
               0.010               0.065
               0.020               0.105
               0.030               0.123
               0.040               0.129
               0.050               0.134
               0.060               0.138
               0.070               0.142
               0.080               0.145
               0.090               0.150
               0.100               0.153
               0.200               0.183
               0.300               0.211
               0.400               0.243
               0.500               0.287
               0.600               0.356
               0.700               0.489
               0.800               0.828
               0.900               2.434
               0.950              11.978
               0.960              24.042
               0.970              74.879
               0.980             460.893
               0.99             12810.97
/FUNCT/13
NULL
#                  X                   Y
              -0.300              -0.546
              -0.200              -0.534
              -0.100              -0.398
               0.000               0.000
               0.010               0.065
               0.020               0.105
               0.030               0.123
               0.040               0.129
               0.050               0.134
               0.060               0.138
               0.070               0.142
               0.080               0.145
               0.090               0.150
               0.100               0.153
               0.200               0.183
               0.300               0.211
               0.400               0.243
               0.500               0.287
               0.600               0.356
               0.700               0.489
               0.800               0.828
               0.900               2.434
               0.950              11.978
               0.960              24.042
               0.970              74.879
               0.980             460.893
               0.99             12810.97
#ENDDATA
/END
  1. Material behavior in tension and in compression is determined by strain rate dependent curves. The loading curve should be defined as:
    • Positive abscissa and ordinate for the compression
    • Negative abscissa and ordinate for traction (tension)
  2. The unloading follows the quasi-static loading curve. This is the first curve of the set of strain rate dependent curves.
    • If Hys = 0, the elastic modulus is used to switch from loading to unloading behavior.
    • If Hys > 0, the following stress reduction factor D MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebaaaa@3724@ is used to switch from loading to unloading behavior:
      σ = ( 1 − D ) σ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHdpGaey ypa0ZaaeWaaeaacaaIXaGaeyOeI0IaamiraaGaayjkaiaawMcaaiaa ho8aaaa@3DFC@
      With
      D = 1 − H y s 1 − W c u r W max S h a p e A l p h a MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebGaey ypa0ZaaeWaaeaacaaIXaGaeyOeI0IaamisaiaadMhacaWGZbaacaGL OaGaayzkaaWaaeWaaeaacaaIXaGaeyOeI0YaaeWaaeaadaWcaaqaai aadEfadaWgaaWcbaGaam4yaiaadwhacaWGYbaabeaaaOqaaiaadEfa daWgaaWcbaGaciyBaiaacggacaGG4baabeaaaaaakiaawIcacaGLPa aadaahaaWcbeqaaiaadofacaWGObGaamyyaiaadchacaWGLbaaaaGc caGLOaGaayzkaaWaaWbaaSqabeaacaWGbbGaamiBaiaadchacaWGOb Gaamyyaaaaaaa@5426@
      Where, W c u r MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiaadogacaWG1bGaamOCaaqabaaaaa@3A3F@ and W max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3A3A@ are current and maximum quasi-static energy.
  3. For stresses above the last load function, the behavior is extrapolated by using the last two load functions. To avoid huge stress values caused by the extrapolation, it is recommended to repeat the last load function.
  4. The initial elastic modulus is set to the maximum value between E 0 and the initial tangent of the input curves. The maximum elastic modulus is minimum value between 100 · E 0 and the maximum curve tangent.
  5. Specific material output variables:
    • USR1: Equivalent stress
    • USR2: Maximum for quasi-static energy, W max MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3A3A@
    • USR3: Equivalent strain rate
    • USR4: Current energy, W c u r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGxbWaaS baaSqaaiaadogacaWG1bGaamOCaaqabaaaaa@3A3C@
    • USR6: Equivalent strain
    • USR7: Stress reduction factor, D MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebaaaa@3724@
  6. /VISC/PRONY can be used with this material law to include viscous effects.
