/MAT/PLAS_PREDEF
Block Format Keyword This material law has predefined elasto-plastic data for some common steel, aluminum, and plastic materials.
| /MAT/PLAS_PREDEF/mat_ID | |||||||||
| mat_title | |||||||||
| Material name | |||||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Material name | Predefined material
name. 3
(Character, must be left-justified when entered) |
Example (Steel)
#RADIOSS STARTER
#- 2. MATERIALS:
/MAT/PLAS_PREDEF/1
Material for generic mild steel
STEEL
#ENDDATA
/END
- This material provides elasto-plastic material data that can be used early in a design when material data might not be available. The data is from the results of several publicly funded projects. The material model defines stress as a function of strain. No strain rate or temperature effects are included. Failure can be modeled by using the same predefined materials in /FAIL/BIQUAD.
- The material data is automatically converted into the model’s unit system defined in /BEGIN.
- This material uses
/MAT/LAW2 (PLAS_JOHNS), Iflag=1 with these predefined values in the units, kg, mm,
and ms.
Name Material Description Density E Yield Stress UTS STEEL Mild steel 7.8E-6 210 0.3 0.160 0.380 0.24 HSS HSS steel 7.8E-6 210 0.3 0.300 0.510 0.23 UHSS UHSS steel 7.8E-6 210 0.3 0.500 1.500 0.045 AA5182 Aluminum AA5182 2.7E-6 70 0.33 0.150 0.300 0.25 AA6082-T6 Aluminum AA6082-T6 2.7E-6 70 0.33 0.300 0.360 0.08 PA6GF30 Plastic PA6GF30 1.3E-6 7 0.35 0.050 0.100 0.02 PPT40 Plastic PP T40 1.2E-6 4 0.3 0.020 0.030 0.06
- E
- Young's modulus
- Poisson's ratio
- Yield Stress
- Material yield stress
- UTS
- Ultimate Tensile Stress (engineering stress)
- Engineering strain at UTS
Note: Altair does not assume any responsibility for
the validity, accuracy or any results obtained from these values. The user must
verify his own values by test results. Usage is only recommended for early
design exploration.
