/SPHCEL
Block Format Keyword Describes the SPH cells.
| /SPHCEL/part_ID | |||||||||
| node_ID | Type | Mass | |||||||
Definition
| part_ID | Part
identifier. (Integer, maximum 10 digits) |
| node_ID | Supporting node
identifier. (Integer) |
| Type | Input type for the mass.
(Integer) |
| Mass | (Optional) Mass or volume
value. Used only if Mass >
0. (Real) |
or
- The particles will have the same identifier as their supporting node.
- The particles should be distributed with respect to a hexagonal compact net or a cubic net (refer to SPH Cells Distribution).
- The particle mass is defined in the property (/PROP/TYPE34 (SPH)) is overwritten by the value defined in the cell (if defined).
