udfGetActSpecId()
The identification number of the current species being solved.
specId = udfGetActSpecId( udfHd ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- specId (integer)
- Identification number of the species being solved. If not within a species stagger, the return value is zero. The return value is one based.
This routine returns the identification number of species being solved in the current stagger.
For
example,
Integer specId ;
specId = udfGetActSpecId( udfHd ) ;Errors
This routine expects a valid udfHd.
