udfGetGlobalHistsCurr1()
Get the current global history variables.
vec = udfGetGlobalHistsCurr1( udfHd, nSize, id1 ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- nSize (integer)
- Size of vector.
- id1 (integer)
- index.
Return Value
- vec (real)
- Pointer to the global vector.
This routine returns a pointer to id1-th current global history variables in
size nSize vector. For
example,
Real* vec ;
vec = udfGetGlobalHistsCurr1( udfHd, nSize, id1 )Errors
This routine expects a valid udfHd.
