udfGetLastStepFlag()
Is this the last time step?
lastStepFlag = udfGetLastStepFlag( udfHd ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- lastStepFlag (integer)
- Flag indicating whether or not this is the last time step.
- 0
- No
- 1
- Yes
This routine determines if this is the last time step. For
example,
Integer lastStepFlag ;
if ( lastStepFlag == 1 ) {
/* Logic if this is the last time step */
}Errors
This routine expects a valid udfHd.
