udfGetMmoRgdData()
Return data from a rigid body mesh motion.
mmoRgdData = udfGetMmoRgdData( udfHd, mmoRgdName, dataName ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- mmoRgdName (string)
- Name of the MESH_MOTION command (must be of rigid_body type).
- dataName (integer)
- Symbolic name of the requested data.
- UDF_MMO_RGD_PREV_DISPLACEMENT
- Displacement at step n.
- UDF_MMO_RGD_PREV_VELOCITY
- Velocity at step n.
- UDF_MMO_RGD_PREV_ROTATION
- Rotation at step n.
- UDF_MMO_RGD_PREV_ANG_VELOCITY
- Angular velocity at step n.
- UDF_MMO_RGD_CURR_DISPLACEMENT
- Displacement at step n+1.
- UDF_MMO_RGD_CURR_VELOCITY
- Velocity at step n+1.
- UDF_MMO_RGD_CURR_ROTATION
- Rotation at step n+1.
- UDF_MMO_RGD_CURR_ANG_VELOCITY
- Angular velocity at step n+1.
- UDF_MMO_RGD_EXTERNAL_FORCE
- External force at step n+1.
- UDF_MMO_RGD_EXTERNAL_MOMENT
- External moment at step n+1.
Return Value
- mmoRgdData (real)
- Pointer to one dimensional real array of the requested data. The dimension of the array is three for all values of dataName.
This routine returns data from a rigid body mesh motion. For
example,
Void usrUdfMmo(
UdfHd udfHd, /* Opque handle for accessing data */
Real* outVec, /* Output vector */
Integer nItems, /* Number of items in outVec */
Integer vecDim /* Vector dimension of outVec */
Real* rotOrg ; /* rotation center */
Real* rot ; /* rotation */
Real* trans ; /* displacement */
String* usrStrs ; /* user strings */
String rgdMmoName ; /* name of rigid body mmo */
Integer timeStep ;/* time step */
Integer i ; /* running index */
udfCheckNumUsrStrs( udfHd, 1 ) ;
udfCheckNumUsrVals( udfHd, 3 ) ;
timeStep = udfGetTimeStep( udfHd ) ;
usrStrs = udfGetUsrStrs( udfHd ) ;
rgdMmoName = usrStrs[0] ;
rotOrg = udfGetUsrVals( udfHd ) ;
rot = udfGetMmoRgdData( udfHd, rgdMmoName, UDF_MMO_RGD_CURR_ROTATION ) ;
trans = udfGetMmoRgdData( udfHd, rgdMmoName, UDF_MMO_RGD_CURR_DISPLACEMENT) ;
udfPrintMess( udfHd, "time step = %d, rot = (%f,%f,%f), disp = (%f,%f,%f)",
timeStep, rot[0], rot[1], rot[2],
trans[0], trans[1], trans[2] ) ;
udfBuildMmo( udfHd, rot, rotOrg, trans, outVec ) ;
for ( i = 0 ; i < 12 ; i++ ) {
udfPrintMess( udfHd, "mmoMtx[%d] = %f", i, outVec[i] );
} /* end of usrUdfMmo */Errors
- This routine expects a valid udfHd.
- mmoRgdName must be a valid name.
- dataName must be one of the values given above.
