2025.1
Discover nanoFluidX functionality with interactive tutorials.
View new features for nanoFluidX 2025.1.
Tutorial Level: Beginner Set up a simple single phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution. Oil distribution will be analyzed and basics of the post-processing in SimLab will be demonstrated.
Tutorial Level: Intermediate Set up a simple two phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution.
Tutorial Level: Intermediate Learn how to post-process nanoFluidX results in ParaView, analyze a simple multiphase gearbox, and plot various transient and time average results.
Tutorial Level: Advanced Learn how to setup a rendering process in ParaView using transient data of a simple multiphase gearbox case and create a rendering video.
Tutorial Level: Advanced Learn how to create streamlines and vectors within a slice.
Tutorial Level: Beginner Set up a moving vehicle wading simulation using SimLab for CFD-nanoFluidX solution.
Tutorial Level: Beginner Set up a static vehicle wading simulation using SimLab for CFD-nanoFluidX solution.
Tutorial Level: Beginner Set up a water management simulation using SimLab for CFD-nanoFluidX solution.
Tutorial Level: Beginner Set up simple single-phase water management case using SimLab for CFD-nanoFluidX solution. The amount and distribution of water will be analyzed and velocity, and forces will be computed.
Tutorial Level: Beginner Set up simple single-phase water management case SimLab for CFD-nanoFluidX solution. The amount and distribution of water on the windshield will be analyzed and velocity, and forces will be computed.
Tutorial Level: Beginner Set up simple single-phase tank case for tank sloshing simulation using SimLab for CFD-nanoFluidX solution. Fuel distribution and sloshing behavior will be analyzed and velocity, and forces will be computed.
Create a nanoFluidX model using SimLab.
nanoFluidX commands and parameters with examples.
Physics and theory for nanoFluidX.
This glossary contains generic messages generated by nanoFluidX, their likely causes, and possible methods to resolve the related issues.
This section provides quick responses to typical and frequently asked questions regarding nanoFluidX.
References used throughout the nanoFluidX manual.
