Create Monitor Surface Outputs
Use the Monitor Surface Outputs tool to create an output surface that is not part of the geometry.
From the Setup ribbon, click the
Output tool.
From the secondary tool set, select the Monitor Surface
tool.
- In the modeling window, select parts to add to the Monitor Surface.
- In the microdialog, select Visual or Summary.
- Optional:
In the microdialog, edit the visual and summary
output.
Figure 3.
Define the Output file format.
- Select either Ensight and/or H3D.
- Optional: Select Merge Output Files to create a merged and individual output files.
- Select Merge And Delete Files to create a merged output and delete the individual output files.
- Optional:
View the Output table and import and export Monitor Surfaces.
- From the legend in the top-left of the modeling window, right-click the active Monitor Surface and select Output table from the context menu.
In the dialog, select
to import Monitor Surfaces.
to export Monitor Surfaces.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating surface outputs.
- Select
to confirm your selection and exit the tool.
- Select
