Define Surface Probes
Use the Probes tool to define surface probes.
Create surface probes.
- In the microdialog, define the start iteration or start time.
- Optional:
Define the start time.
In the microdialog, click
and specify the variables being solved for.
Figure 4. -
In the microdialog, define the output interval,
refinement level, or target frequency.
Tip: The output interval can be specified in fractions to support sub-time step data from finer mesh regions.
- Optional:
Define the refinement level.
The output interval is automatically set.
- Optional:
Define the target frequency.
- Optional: Define the radius from the Property Editor.
Define the Output file format.
- Select either Ensight and/or H3D.
- Optional: Select Merge Output Files to create a merged and individual output files.
- Select Merge And Delete Files to create a merged output and delete the individual output files.
- Optional:
Import and export surface probes.
- From the legend in the top-left of the modeling window, right-click the active probe set and select Probes table from the context menu.
In the dialog, select
to import surface probes.
to export surface probes.
For more information, see Import, Export, and Edit Output Controls. - Optional:
Create probes based on a polyline.
For more information, see Create Surface Probes from Polyline.
Change the color of probes.
Move probes in the modeling window.
From the guide bar, complete one of the following:
- Select
to confirm your selection and continue creating sets of probe points.
- Select
to confirm your selection and exit the tool.
- Select
