- Braking In a Turn
A Braking in a turn event simulates a vehicle decelerating in a circular path.
- Constant Radius
A Constant radius event simulates a vehicle driving in a circular path, typically with increasing speed. The event predicts the vehicles roll and understeer characteristics with increasing lateral acceleration.
- Double Lane Change
A Double lane change event drives the vehicle through a lane change and a return to lane maneuver, attempting to follow the centerline of the defined lane.
- Driver File
The Altair Driver File event allows you to run your own Altair Driver File and use this file in the event.
- J-turn
The J-turn event (or Fishhook maneuver) simulates the vehicle response to a large steer in one direction, a dwell time to allow the vehicle to react, and a large steer in the opposite direction, with an additional reaction time.
- Mass/Inertia Setup
The Mass/Inertia Setup event is used to modify a specified body’s mass properties (mass, CG and optionally inertia tensor) to achieve a desired set of model (global) mass properties.
- n-Post Shaker
The n-Post Shaker event simulates a vehicle supported on a test-rig by posts.
- Power-off in a Straight Line
A Power-off in a straight line event simulates the dynamics of a vehicle due to a sudden removal of drive torque.
- Pulse Steering
A Pulse steering event simulates a vehicle response to a sudden pulse input to the steering wheel while driving in a straight line at a constant speed.
- Road Course Drive
The Road Course Drive event can be used to simulate full vehicle models on the required road profile. Different path and velocity profiles can be specified to validate the vehicle behavior on the specified road. The event also provides a means to study vehicle performance in the areas of durability/fatigue and ride comfort.
- Single Lane Change
A Single lane change event drives the vehicle through a single lane change, attempting to follow the centerline of the defined lane.
- Sinusoidal Steering
A Sinusoidal steering event simulates a vehicle driving at a constant speed while a sin wave input is applied to the steering wheel.
- Slalom
A Slalom event drives the vehicle in a straight, followed by a sequence of turns around cones in alternate directions with constant vehicle velocity.
- Stability Analysis
The Stability Analysis event can be used to simulate two-wheeler models on various road surfaces to evaluate the weave and wobble modes of the vehicle. A user-defined road property file determines the road input.
- Step Steer
A Step steer event simulates vehicle response to a sudden step input to the steering wheel.
- Straight Line Acceleration
A Straight line acceleration event simulates a vehicle accelerating at a constant rate in a straight line.
- Straight Line Braking
A Straight line Braking event simulates a vehicle slowing in a straight line.
- Swept Sine
A Swept Sine event simulates a vehicle driving at a constant speed with a sinusoidal steering input of constant magnitude but increasing frequency applied.
- Swept Steer
A Swept steer event simulates a ramped steer input into a vehicle driving at a steady speed.
- Throttle-off Cornering
A Throttle-off cornering event simulates the dynamics of a vehicle driving a constant radius turn at steady state and the reaction of the vehicle due to a sudden removal of the drive torque while cornering.
- Throttle-off Turn-in
A Throttle-off turn-in event simulates a vehicle driving straight at constant speed, turning on to a constant radius, then after reaching steady state the throttle is closed and the steering is ramped to tighten the turn.
