Create Fatigue Responses
Use the fatigue tool to create damage and life responses for selected elements.
Restriction: Fatigue responses are only supported for the OptiStruct profile.
From the Design Explorer ribbon, click the
Fatigue tool.
- From the guide bar, select Damage or Life.
- In the modeling window, select elements.
- Optional:
In the microdialog, select
Objective or Constraint to
simultaneously create one.
Note: You can continue to define the constraint in the microdialog.
- Make any desired modifications to the created response in the microdialog.
Click
on the guide bar to create the response.
