Create Gauge Inputs
Use the Gauge tool to create design variables based on the thickness of selected properties.
Note: For Generative Design explorations, gauge inputs are intended for non-design space
entities.
From the Design Explorer ribbon, click the Gauge
tool.
Select properties.
Gauge input values can be entered in one of the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
- As a continuous range of values, where the lower and upper bounds are specified specifically.
- As a list of discrete values.
In the microdialog,
- Select how you would like to define the input values, then either specify the lower and upper bounds or specify a list of valid discrete values.
- Click Create.
