Create Size Inputs
Use the Size tool to create size design variables based on the attributes of selected entities.
Note: For Generative Design explorations,
size inputs are intended for non-design space entities.
From the Design Explorer ribbon, click the Size
tool.
- Use the drop-down menu on the left side of the guide bar to choose an entity type.
Select entities of that type.
A size input's values can be defined in the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
- As a continuous range of values, where the lower and upper bounds are specified.
- As a list of discrete values.
In the microdialog,
