Contact
This realization creates set-based contacts between areas identified by the connector projection.
Contact Realization Options
Option Action
Connectivity Enables the growth of the patches in the contact.
Card Image Can be used to define the type of Contact the connector will create. The options are:
  • Surface to Surface
  • Node to Surface
